Change Polarity on 3rd Brake Light on Lid
Originally Posted by Dharn55
I bought two smoked brake lights from Carnewal. Installed both, one fixed and one on spoiler, both work fine with no change in polarity.
Hence the heads up for a possible swap in Sharky's instructions.
Thanks again for all of the feedback. Anyone have more info on the cruise control not working? That is a bad consequence.
Further, Is it really as simply as pulling the pins out of the LED light (for the lid) and swaping them? That wouldn't seem to change the current flow, but rather just the pin. Is the only real solution to splice the wires and switch them?
Anyone have a link to some pictures of DIY?
Originally Posted by kevinrubin
.... Is it really as simply as pulling the pins out of the LED light (for the lid) and swaping them? That wouldn't seem to change the current flow, but rather just the pin. Is the only real solution to splice the wires and switch them?
As your situation stands, your car has the current flow going in the wrong direction for the diode portion of the Light Emitting Diodes that you are using to replace the plain light bulb. A diode is a one way check valve for DC current. If you feed DC backwards through a normal light bulb ... no big deal. If you feed it backwards through a diode, it will not pass through. Stops. Dead .... just as if you cut one of the wires.
By switching the pins in the brake light connector, you remedy this wrong direction flow by changing the terminals of the positive and negative leads. Now the current is going the proper direction to pass through the diode. The same thing can be accomplished by cutting and cross-connecting the wires between the connector and the LED brake light (but don't do both methods, or you'll be right back where you started).
hey guys sorry I've been away at a show.. Just wanted to make sure this got taken care of. It's pretty fidly but all that needs to be done is to change the two pins on the connector/harness around (swap em). It's fiddly and be gentle!
Either way, I usually just sell the ones that are plug and play. The one that goes in the wing is a bit fiddly having to change the polarity of the pins and hence I try not to sell those unless we do it here... I think that one was "free" so you can keep it any case as an extra or if you do try to swap the pins just be gentle..
Thanks Alex. I can't thank you enough for all your help. Hope you had a great time at the show!!!
Originally Posted by wwest
Be aware that if you change all brake lights to leds as I did your cruise control will not work. I had to add a load resistor in parallel with the brake leds.
Thorsten
