Broken Convertible Top Cover
All of a sudden today the convertible top cover seems to have broken. When I attempt to open or close the convertible top, the cover only swings open on the drivers side, the passenger side doesn't budge, and then the whole thing just grinds to a halt.
Looks like this is going to be the first extended warranty experience for my reign of ownership. Has anybody experienced this before so I can get a feel for what to expect?
Cap'n Insane the Engorged
Are you talking about the flaps on either side?
If so feel around and see if it's getting caught up on something.
Are you referring to the clamshell? .......The piece that painted in exterior body color and extends away from the car to allow the top to be stored partly under it.
Problem solved. After tinkering around I figured out that the pin which translates the motion of the actuator to the lever arm which raises the clamshell on the passenger side had come loose and popped out (see photos). Simply had to stick it back in. It seemed to be held in place only by friction. Thanks everybody.
