Front tires cannot be rotated?
I guess you technically 'could' rotate them (by 'rotate' I assume you mean move the RF to LF position and vice-versa). but the tires are typically unidirectional and at least the factory turbo twist spoke pattern will be reversed if you switch sides.
Depending on your specific wheel/tire combo the above may or may not apply to you.
.. the factory turbo twist spoke pattern will be reversed if you switch sides..
Originally Posted by slaaw
I don't believe the turbo twist wheels are unidirectional, so that should not make a difference. Only if the tires are unidirectional would it affect the rotateability.
Bigger issue is that unless you're racing NASCAR style with only left turns wearing down one side it's probably just a waste of time to bother with rotating them. ymmv.
