Tires help!!!
I already ordered a set of HRE`s 542R for my Basalt Black 03 C2, 19x8.5 ET40 and 19x11 ET58 I will fit Potenza`s SO3,
Current tires (17`s) diam: 25.1" vs (245/35 and 285/30) 25.7" , is it ok???
2.-
2.-
Thanks, just to be clear, I ordered 19x11 after double checking with HRE , and my question is:
Is the +.6" tires diameter difference (17`s VS 19`s ) is inside the "tolerances" without affecting speed reading, etc? .
Thanks in advance,
Jorge
Thanks in advance,
Jorge
yes, the tire size is fine, but a 285 will stretch quite a bit on a 11" rim - it looks and fits better on a 10.5 IMO...we recommend 10.5 as the max fitment, but an 11 CAN work, but sometimes it is more hassle than it is worth - plus, you aren't gaining any lip going to a 11" from a 10.5".
I recommend a 295 as the minimum on an 11" rim, but that is too tall for a C2...
I don't understand why you want to get 11" on the back. There are ten reasons not to, and no reasons for it?
If you want to track the car for more grip, those are not track wheels plus you will suffer from understeer(too much unsteerable grip going straight esp. on a C2). Appearance wise from the outside there is no difference between 10 and 11. The lip on the outside will be the same size.
