Thermo-Tec Insulating Wrap
Anyone try this on the headers? Just curious, I keep seeing it in catalogs but I don't know anyone that uses it, (that might tell me something right there), but I thought I would uncork it on the Rennlisters and see what you say.
http://www.automotion.com/productpag...rap+by+Cool+It
i have used a similar wrap on my subaru's exhaust, but not the headers, only the part immediately after the turbo. it works, noticably, less ambient heat in the engine bay.
do a GOOD job of wrapping the headers ie equal spacing between wraps, no exposed areas - that will reduce chances of cracking the headers. in addition, get high-temp exhaust spray paint - a few coats will help seal the wrapping and keep small particles from flying off. that wrapping tape feels like burlap but worse. USE gloves, otherwise you will get fiberglass splinters. hope this helps, even though not porsche-specific
Technical Guru
Over the years I've heard of problems with these type of wraps trapping moisture and causing premature corrosion issues. And, for a normally-aspirated motor I wouldn't expect any quantifiable performance gains. If you are looking for a fun weekend project try a ceramic coating, places like Caswell plating sell them to the DIYer. Or you could just send everything off to someone like Jet-Hot, they shouldn't be too expensive?
