996 Forum 1999-2005
Volt meter position
Old Jun 26, 2003 | 03:41 PM
Jeff996Canada's Avatar
Jeff996Canada
Post Volt meter position
Hi All,
Where does the needle for your volt gauges usually sit? Ours is usually around the 13 mark. Also, after starting the car (especially when hot) the needle sits around just about 12 for a while and slowely moves up eventually. Does this sound normal?
Thanks,
Jeff.
Old Jun 26, 2003 | 03:42 PM
Jeff996Canada
Post
Sorry,
No problem with car as far as I can tell, it just seems to sit lower than it did on our 928 for example.
Old Jun 26, 2003 | 07:48 PM
wwest's Avatar
wwest
Post
Regulator is designed to charge the battery to a slightly higher voltage in colder weather than hot. Above 14 is not unusual in the wintertime.
