996 Forum 1999-2005
HELP ASAP MUFFLER INSTALL
Old 04-09-2006, 09:12 PM
42empress
42empress's Avatar
Exclamation HELP ASAP MUFFLER INSTALL
Wheels are off, Muffler is loose from cats, BUT I can not find the third 13 mm hex nut to remove the muffler bracket. I took out the two down low, but can't get the long bolts out of the bracket. My car is an 02.
Old 04-09-2006, 09:29 PM
mrcook02996
mrcook02996's Avatar
If I understand you correctly, the long bolts don't have to come off. They hold the bracket to the muffler which is taken off once the muffler is out of car, and is used on the new muffler. As for the 3 nuts, If I remember correctly there are two towards the rear wheel (one above the other by about 3 inches or so) and the third is about 6 inches or so left of the bottom nut. They are in a tight space (in muffler bracket) and are hard to get to and can only be turned about 1/2 turn at a time.
Hope this helps some. Good luck.
Old 04-09-2006, 10:33 PM
Kims996Cab
Kims996Cab's Avatar
Two of the studs with 13mm nuts are directly in line vertically (high and low on the plate).
The third is in line with the high stud, about 4 inches across the plate.
Trying to upload a picture of a bracket out of the car ... but my camera picked a bad time to give up the ghost.
Old 04-09-2006, 11:01 PM
1999Porsche911
1999Porsche911's Avatar
Here you go:
Old 04-09-2006, 11:35 PM
TT Surgeon
TT Surgeon's Avatar
When you initially pull the muffler, leave the bracket and two long bolts in place, the three nuts that attach are visible. If you can move the muffler freely, you may have only had two, as it is a common trick when changing out mufflers to only use the easy two to hold it on, discarding the third(bitch)one. Your car may have had a muffler change in the past, good luck, keep at it!
Old 04-10-2006, 12:59 AM
42empress
42empress's Avatar
GOT IT!!!!!!
found Loren's pic on renntech. I was stupidly taking the bracket off the bottom of the motor. Once i figured out i was in the completely wrong place, i saw the 3 correct nuts. I did put the bracket back on before remounting the mufflers, but did switch the bolts upside down as Chris suggested. The hardest part was getting the tips off and then back on. I do not think the had been touched in4 years, 53000 miles of daily crap on them. Anyway took her for a spin and it is just the type of enhancement sound i was looking for. Thanks to "Bob in NY" for the sale.
Time for bed
Thanks again for all the help and support
Jeff
Old 04-10-2006, 03:12 AM
m5guru
m5guru's Avatar
Glad I saw this post as I will be doing the same thing later today (hopefully).
Can't wait.
David
Old 04-10-2006, 09:06 AM
gota911
Newbies Hospitality Director
gota911's Avatar
Jeff & David - you didn't state in your posts exactly WHY you were swapping exhaust cans! A stock set of cans modified (hacked) to sound like PSE, maybe?
Old 04-10-2006, 01:50 PM
42empress
42empress's Avatar
I was going to do the hacked PSE, but found the GHL's at a good price. I still may do the hacked PSE with my stock cans. Although, the GHL are smaller and lighter, more than i was anticipating, and were relatively easy to put in. I found the REMOVAL of the old ones, was by far the hardest part because they had been on there so long. I was looking for a better sound. These are nice, but the hacked PSE will probably have a deeper sound. Hopefully i will be able to do a good compare one day.
Old 04-10-2006, 02:05 PM
Kims996Cab
Kims996Cab's Avatar
..... I found the REMOVAL of the old ones, was by far the hardest part because they had been on there so long. .
I have seen several comments like this lately, and concluded it must have something to do with the environment in which the car is operated.
Others should not be discouraged from a muffler project simply because they have older cars. My Cab is over 5 years old, with 52K miles .... and the cans came off with just a few (15-20) minutes per side. No rust, no crud, no chemicals or muscle necessary.
Of course, the time was cut by the fact that I already had the bumper and heat shields off .... but that was not a factor in the freeing of nuts and bolts.
Old 04-10-2006, 02:41 PM
m5guru
m5guru's Avatar
Well, for me, I was looking for a different "sound signature" and bought a set of Fabspeed mufflers.
During a break at work today, I managed to go home, get a snack, and swap out one muffler. I was pleasantly surprised at how easy it was to break the nuts/bolts free. My car is a 2002 with 30,000 miles. It did spend most of its life in California and Nevada, though.
Hope to get done with work today and get the other side.
So far, so good. The sounds is much more aggressive and (to my ears) pleasant. It is definitely louder under load, but under light load the sounds is very mellow. The tone has a much lower, rumblier character.
David
Quick Reply: HELP ASAP MUFFLER INSTALL
