Wheel Spacers ?
04-01-2006, 10:56 AM
Wheel Spacers ?
I'm looking at purchasing some wheel spacers to give my 99 996 cab more of an aggresive look. What size works well without the rubbing issues.
04-01-2006, 11:22 AM
Chandler!Rennlist Member
I use 6mm spacers - just enough.
ymmv.
Rob
04-01-2006, 11:47 AM
Did you use 6mm spacers on the front and rear ?
04-01-2006, 12:44 PM
04-01-2006, 04:50 PM
Riad,
Does it matter that your car is a wider track C4? Would 6mm work fine on a C2?
04-01-2006, 06:18 PM
spacers
you can go as radical as 15mm rear and 7mm front like i did. NO rubbing issues whatsoever and my c2 is slammed with pss9s
04-01-2006, 06:31 PM
I did the Porsche Teq 5mm set (includes F/R and new longer bolts and locks). Perfect!
04-01-2006, 06:47 PM
Is bolt length going to be an issue when using 6mm or 5mm spacers ?
04-01-2006, 06:49 PM
It is if you do NOT get longer bolts.
04-01-2006, 07:33 PM
I did the 7/15 F/R on a previous 99 and it worked fine. (use the longer bolts!) With an aftermarket wheel and and less positive offset you might have an issue.
04-01-2006, 07:38 PM
Yes you can go as high as 15mm rear, but I didn't want anything that drastic.
Dell, did you get longer bolts with your 5mm set? I only have longer bolts for my 25mm rear spacers for my winter tires.
Rob
04-02-2006, 01:13 AM
Hey Rob!
The Porsche Tequipment set comes with everything. Spacers, longer bolts and locks. See attached pic.
04-02-2006, 01:20 AM
Yes you need longer bolts even with 6mm spacers.
04-23-2006, 05:16 AM
Do you need longer bolts for 3mm spacers?
04-23-2006, 06:49 AM
do you see (looks) and notice (driving) difference with 5MM spacers?
