Wheel Spacers ?
Originally Posted by Nicolaasdb
do you see (looks) and notice (driving) difference with 5MM spacers?
I went with 17mmR/5mmF
Works perfect ! Car looks so much nicer now.
No difference in handling (from a daily driver point of view).
I posted a write-up last week of my install + some nice pictures. Perform a search under my name.
Originally Posted by 997driver
Do you need longer bolts for 3mm spacers?
Hey LV, I only need a tiny 3mm up front because my rim is slightly rubbing up against the collar of my bilstein PSS9's. So do you think I can get the 3mm and not have to get the extended bolts?
Golly....just my opin guys but I sure wouldn't waste my time with 3-5mm .....what's 3mm, something like less than 1/8".....my eyes aren't good enough to see that.....congrats if you can.
Here's the equivalant of 15mm rear, 9mm front (on 18" 8J, 10J).....ie 43 and 50mm offset on these HRE's (on a lowered narrow body).
![](http://www.986host.com/albums/GreggT/front_cab.jpg)
Sorry to say Gregg, but it just looks like your rear wheels stick out a bit too much and obsure the curve of the wheel wheel around the tire. To my eye, the wheels are not supposed to be flush with the fender in terms of design, but just inside. Gives it that classic look.
I will add that your wheels look terrific though from what I can see.
![](http://www.986host.com/albums/GreggT/mountain_pic2.jpg)
