LSD for 996?
8th Gear
Does anyone know if there is an LSD option for the 996, specifically whether there will be one on the 2002 model?
thanks
terry
Terry's 911 page
thanks
terry
Terry's 911 page
Haiku Grasshoppa
Can I Drove Your Car?
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
Someone will certainly correct me if I'm wrong, but... No, you can't get LSD. It was available in '99, maybe in '00, but no more.
PSM (stability management) is not compatible with a coventional LSD, hence conventional LSD deleted when PSM introduced. The reason is that the PSM works by applying individual wheel brakes to stabilize the car, this would be confounded by a conventional LSD. You can buy LSD for early 996 and install but you will have to deactivate the PSM.
Cupcar,
I believe the Corvette uses both an LSD and an active handling system, so I don't think these systems are fundamentally incompatible. I do think there may be other reasons. First, dropping the LSD is a cost savings. Second, on the street, PSM seems sufficient for reasonable balance without LSD. And finally, the 996 MY99 LSD is a chinsy 2 plate plus 2 spacer design that wears out rapidly.
Mike
Mike
Mike- Good point about the Corvette. My information is from a factory Porsche service book: "Service Information Technical Introduction Model Year 2001 911 Turbo", part number PNA 488 120. In this book on page 3-1 in the Manual Transmision section it has a note that says: "The Porsche Stability Management system (PSM) is standard equipment on the new 911 Turbo. As a mechanical locking differential would have an adverse effect on the PSM system, the 911 Turbo cannot be equipped with a locking differential". I assumed this was the case with all Porsches as PSM appeared as LSD's dissappeared. Interesting that the LSD was so chinsy anyway. Too bad the 911 didn't come with the G50 based gearbox and LSD the GT3 did.
Originally Posted by Mike Schuster
And finally, the 996 MY99 LSD is a chinsy 2 plate plus 2 spacer design that wears out rapidly. Mike
Are you saying that if I go with a '99 996 with P72 option code (220, 222, 224--locking diff, anti-slip, active braking diff) that I'll need to replace the diff clutches on a regular basis? How often, and how much $$??!!
Originally Posted by SleepRM3
This is disconcerting? Mike, my old '93 Mazda Rx7 Twin Turbo (Type FD) came with a Torsen limited slip, and I never had problems with it, except for changing the diff fluid once a year? My current '97 E36 M3/4-door also has a variable locking/limited slip diff, and needs no other maintenance except for diff fluid changes.
They are designed to wear just as brake or clutch linings do. The difference from brakes or clutches, when they start wearing it isn't as noticeable since the diff still functions; just more as an open diff than a locking one.
The LSD is very durable and mine continues to work as new even after 55,000 miles of hard driving. It is not common for needing any other maintenance other than lube change.
thanks
terry
Terry's 911 page
thanks
terry
Terry's 911 page
There was no LSD option for the 996 in the US in 2002. It is a load of BS for anyone to say that the LSD is incompatible with PSM. All 2004 40th Anniversary Jahre editions had both mechanical limited slip differentials(only 20%/40% locking) and PSM standard. What's more, the LSD has continually been an option in Europe and is so today (check out the options on the UK or Germany Porsche sites). It just hasn't been optional for the US market.
I was told by Brian Copan that he could put an LSD in my 02 if I wanted one.
i beleive cupcar is correct that there has been no LSD option on 996 cars since/because of PSM. this is also true of 997 cars, except new 997 turbo which also has PSM standard does have option now for "LOCKING DIFFERENTIAL". they are not calling it LSD.
more to come
cooz
aka
norm mandell
more to come
cooz
aka
norm mandell
FYI,
Keep in mind PSM is standard on all 997's. Here it is quoted from the 997 option list of the Porsche UK site as part of the sport suspension option:
Sports Suspension (- 20 mm) including mechanical rear differential lock:
Suspension lowered by 20 mm front and rear; stiffened springs, dampers and anti-roll bars; includes mechanically locking rear differential (multi-plate limited-slip differential)
Here it is in German off the Porsche Germany website:
Sportfahrwerk (- 20 mm) inkl. mechanischer Hinterachsquersperre:
Tieferlegung um 20 mm vorne und hinten, straffere Feder-, Dämpfer- und Stabilisatorabstimmung, inklusive mechanischer Hinterachs-Quersperre (Lamellensperre) Hinweis: Nicht in Verbindung mit PASM.
Originally Posted by 02 Carrera
FYI,
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Terry,
