996 Cooling solutions
#46
Thanks for the offer but unfortunately I have more wall art than I have walls. Hopefully others here will take you up on that RL price though. They really are great pics...would look great hanging in the garage, game room, office, etc.
#47
A quick way to check the low speed fan operation is to start the car and turn on the AC. The fans will always run at low speed(unless the engine temp is too high, in which case they would run on high speed) while the AC is on.
#48
Hi all,
I've just picked up on this and have a few questions if anyone can advise. Did anyone figure out which was the ground on the relay? I've read the posts and can't find an answer and when you run the two grounds from relay 21 and 22 I take it you connect both to one side of your switch and then run a ground to the chassis from the other side of the switch. I'm thinking about a gen Porsche switch as I've got a couple of spare slots, has anyone tried this?
