996 Forum 1999-2005
lowering & wheel size question.
Old Feb 28, 2006 | 12:02 PM
delirium's Avatar
delirium
Default lowering & wheel size question.
I have 18" wheels right now, and I want to lower my car. In the future I want to get 19" wheels... will I have to raise my car a little when I get the 19" wheels or will the car remaiin the same height? I am guessing if I go with a wider 19" wheel I may have to raise it because it may rub the fender...
Old Feb 28, 2006 | 12:08 PM
LVDell's Avatar
LVDell
Depends on too many factors:
Size (width and sidewall) of Tire
Offset of Wheel
Width of Wheel
Amount of Suspension Drop
Old Feb 28, 2006 | 04:18 PM
Nicolaasdb's Avatar
Nicolaasdb
I am having my P lowered right now....have 18" . Depending on how much you go "down"..I am having H&R's installed (1.25 lower) and they told me there would be no problem putting 19" on.....
Old Feb 28, 2006 | 05:27 PM
Eli K's Avatar
Eli K
Yes, you can easily run 19s with correct offset and appropriate tires.
Old Mar 1, 2006 | 05:42 AM
Nicolaasdb's Avatar
Nicolaasdb
just got my P lowered...1.25" with H&R springs and there is enough space left for 19" wheels. Would even look a little better with 19"......but my front turbo conversion is first!
