Upgraded to 19's - thanks Tim! Question though...
#61
I haven't been able to put the 275's on yet. My wife had our second baby last Thurday so things have been busy! There's construction in my neighborhood and I driving my P through it makes me nervous so I've put it off. I do think that there's slightly a stretched look, but I don't mind that look. I think your wheels look great. I realize I'm in the same dilemma, but that's not a biased opinion at all.
I'll post pics once I have them on, but like I mentioned, I already know what they'll look like (Tim's ride) =)
#62
Here are pics of 19's on my narrow body....19x11, 67 offset, 295/30/19....it fits PERFECTLY...you guys need the CORRECT offsets. 275 is too narrow for that wheel. I didnt buy those wheels because the offset was incorrect....generic wheels with generic offsets....as for iForged....wouldnt they send you a new set of rears? 19x11 with a 65 or 67 offset is perfect....why go 10.5 anyway?
#63
Looks good. I think it's established that getting close to 65 is the way to go. All the other stuff with tire sizing is trying to accomodate the offset. The only question I have for you is whether or not you notice the overall diameter being larger w/ the 295's. Doing the math, the 275's was the closest to stock in diameter. Then again, the new 997's have the 295 set up. Does that make a difference in rpm's or speed? By the way, what's the offset on front?
#65
those are the 997 Sport design 19" wheels...factory. i had them custom painted black....No difference in speedo or RPM's....less understeer than my 18's and believe it or not...smoother ride....
#66
Don't you think that 996 is set to work with 18" wheels?
Perhaps 19" rims are more beautiful and so on , but the suspension will not work as fine as they were designed by Porsche engineers.
Otherwise they wolud fit these bigger rims into the 996 series.
I don't know how you say it in english, but I was wondering about the conversions (or equivalence or development ) of the wheel. You've changed it with unsuitable messures, haven't you?
#68
Thanks LVDell , but what I was trying to explain was the equivalence between different diameter-wheels and tyres with the same development. I meant the gearbox ratio. This ratio would be changed if you don't keep on the same development of the wheel . If you alter the diameter the gear ratio would offer different speed max, acceleration , etc.
Sorry if I can not explain better , but it's difficult for me technical english
#70
One of my favorites is the follwing: (it allows you to enter your current size and then compare up to 4 more. http://www.1010tires.com/TireSizeCalculator.asp
#71
Originally Posted by LVDell
Rolling diameter can be measured very easily with several online calculators.
Rolling diameter !
Thanks .
This site makes it so easy.
#73
Originally Posted by nycebo
Newport, holy moly your car and wheels look FANTASTIC. It looks like one of those spy snapshots.
#74
thanks guys...its a 99 C4 Cab with the 02+ facelift with a Turbo Bumper, converted Turbo rear bumper, GT3 mk II sideskirts, 19" 997 Sport Design wheels, Kenwood touchscreen double Din DVD/Nav/MP3/iPod controller, and tons more.....
