Is this the dreaded RMS leak?
Originally Posted by PorscheDoc
See...it had a happy ending
$43K for the GT3 motor. Do not worry about the RMS. The reason I got the engine was because it was covered and the block did not meet spec. RMS will not lead to having to replace the engine.
Originally Posted by faris13
damn it....4 in 6 months??? I think i might have to jump to a c4s now
the C4S has the same block/RMS design as the 3.4 c2/4, 3.6 c2/4. your odds of getting another RMS leak in the c4s, unfortunately, would be the same. you would better chance of not getting an RMS leak with the gt3/TT/gt2, because of the different block, but they too are not immune.
thanks for the info guys...well looks like I'll just deal with it, it's not going to stop me from enjoying the p-car . hopefully my aftermarket warranty will cover it.
good luck
Unfortunately that's not necessarily an accurate statement. In a small minority of cases, an RMS leak will require a new engine for a permanent repair. There are lots of threads on this forum that cover this issue in detail.
fast1: you are correct. That is what happened to me. What I ment is that his engine will not let go as a result. If I had an out of warrenty 996 I would not buy a new engine to get rid of the leaks I had < quart every 800 miles.
Thanks for keeping me straight.
