Weekend Mod... Red Calipers... Pics
#166
Jp - OK, one more item to add to your mod list is painting the "top hats." Since my wheels are silver I painted the top hats silver also as shown in the pisc below.
However, since your wheels are black, you might want to consider painting the top hats black like Steven (TheSpeedDemon) did on his car. Here is a link to some pics of his black hats.
https://rennlist.com/forums/showpost...21&postcount=1
Resurecting this thread because I want to do this project as soon as the weather permits.
So how did you get the paint around the smaller details on the caliper, like the nipple, the small recessed nub in the hole above the porsche logo, and the two rings below the porsche logo? (See red arrows) I assume you masked the nipple and the nub, but it seems like it would be tough to get paint around the base of the nipple without removing it, and hard not to get paint into the recess of the nub. What's your secret?
Thanks for the descrip on lifting the car lifting process. Very helpful for a first timer like me.
#167
Hi Tim,
Until Tim has a chance to reply I (Tim too) thought I'd share my experience with this mod. I masked off the bleeder screw and didn't worry about the other points you've highlighted. I did mine over two years ago and they've held up very well. Here is a link to the thread: More painted calipers Good luck!
#168
Newbies Hospitality Director
Hey Tim, Tim here.
Red calipers would look awesome on your Basalt Black car!
The answer to your question is.....TAPE! Here are a couple of pics I took when I sprayed the clear coat on the calipers. When I painted the calipers I didn't put the plastic bag over the brake rotors.
I painted around the small hole but just painted over the two "rings."
Make sure you buy a better brush to replace the brush that comes with the Dupli-Color paint.
Also, check out my other thread about painting the "top hats" (hubs). Do a search in the title only on "hat" (singular) and threads started by "gota911"
Hope this helps!
#170
Parts Specialist
huh - well what do ya know....
I thought it was basalt too - still very nice color
Tim's calipers turned out really nice. I personally never did this because I have seen some that didnt turn out so well... looked a little cheezy with paint over all the pieces and even on the backing plates for the pads, I mean from standing and looking they are fine, but when you really look close - not so much -
I think being careful and doing a really good tape job is were you get the best rewards and the best results...
#171
The four standard colors (Black, Guards Red. Carrara White, and Speed Yellow) are non-metallic colors.
Ed, he is a Newbie so I'll cust him some slack, but you should know better!!!
#172
Uhmm, Basalt Black IS the metallic version of Porsche Black, so you can keep your current screen name
#173
The car is spelled Carrera, but the color is spelled Carrara, as in Carrara, Italy, where Carrara (white) marble is mined.
BTW, Michelangelo carved many of his sculptures in Carrara marble.
#174
How does the red hold up in a high heat setting such as a track day? Ive seen red calipers turned brown from the heat...has anyone who has done this tracked them?
#175
I didn't track my car so I can's say how they would hold up under repeated hard braking.
However, after 2.5 years of normal daily driving, my calipers looked to be 95% as good as the day I painted them. I attribute the 5% drop because they were slightly less shiny because of washes and brake dust.
#177
Uhmm, Basalt Black IS the metallic version of Porsche Black, so you can keep your current screen name.
Edit: Found this - http://www.911c1.de/porsche/Technik/...de_schwarz.htm
#178
I can't find it now, but I found a master porsche paint code list somewhere and Basalt Black was code LC9Z, while mine is L744 and listed as Metallic Black.
I thought you car was an '02. My bad.
#179
Parts Specialist
