Valentine One / Windshield Mount
Has anyone had any problems using their Valentine One's with the windshield mount? I've been told that some earlier Porsches had a film on the inside windshield that was discolored if the suction cup mount was used. I've just been clipping mine to the visor. Thanks.
tvg
02 996 C2
tvg
02 996 C2
Basic Sponsor
You definitely want it on the glass, not the visor. If you have trouble, clean the glass using a vinegar solution (might have an odor) and let dry.
Then go over it with Invisible Glass (Stoner) or similar glass cleaner if you need to, and after drying, mount suction cups.
Be absolutely sure the detector is NOT in the tinted section of the upper glass - this will diminish the detection capability.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Mark: Check out this site for some info on wiring up the V-1 to a switched circuit. Ignore the info on the V1 unit placement, as that's unique to the Boxster. I used this factory phone power source in the console area for my hook-up. Hope this helps. <a href="http://boxsters.addr.com/hacks/stealth_v1.htm" target="_blank">V1 Install</a>
I had no problems with mounting the Valentine on the windshield in either my '99 996 or the '02 996. Just make sure it is high enough so that it can get a reading out the rear glass.
