996 Forum 1999-2005
Traction control vs PSM, e-gas
Old Jan 16, 2002 | 12:45 AM
Dr. Z's Avatar
Dr. Z
Question Traction control vs PSM, e-gas
I just purchased a 99 996 which was manufactured July 99...when did e-gas become standard equip? My car has traction control with ABD...what is the difference between traction control with ABD and PSM?
Old Jan 16, 2002 | 01:36 AM
Viken's Avatar
Viken
Keeper of the Truth
Post
Drive-by-wire was standard on the '99 Carrera 4 and became standard on all 2WD Carrera's and Boxster's as of MY '00. The following explains TC, ABD and PSM.
From Porsche:
TRACTION CONTROL Generic term for electronic controls that reduce drive wheel slippage, intended especially for low-traction conditions. Taking advantage of the sophisticated software already employed by ABS systems, any wheel can be slowed by selective brake application in order to help the retain traction. Other systems automatically modulate the throttle. The more sophisticated traction control systems utilize both capabilities.
ABD (Automatic Brake Differential) A type of traction assistance which applies the brakes to a slipping wheel, transferring torque to the opposite wheel. ABD systems generally operate at lower vehicle speeds.
Porsche Stability Management (PSM) is designed to stabilize the car when driver loss of control is impending. PSM uses a number of sensors that provide input to a high-tech control unit. The unit continuously checks and compares input from the sensors to determine the vehicle's direction and movement and how it differs from the direction chosen by the driver based on steering-wheel input. If the system senses that the vehicle is deviating from its proper path while accelerating or coasting — by oversteering or understeering — it takes corrective action by selective braking, throttle change, and gear change on Tiptronic equipped models.
Old Jan 16, 2002 | 11:32 AM
bloke's Avatar
bloke
Post
Just a follow up. I dont have PSM but does the 2000 C2 have any kinda traction control?
thanks
Old Jan 16, 2002 | 12:04 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
Originally posted by bloke:
<STRONG>Just a follow up. I dont have PSM but does the 2000 C2 have any kinda traction control?</STRONG>
For 2000-on, you could get PSM as an extra option. It was option M476 and listed for $1215.
Old Jan 16, 2002 | 01:28 PM
bloke's Avatar
bloke
Post
viken,
thanks for the info but i really wanted to know if there is regular traction control like an M3 which i used to have.
Old Jan 16, 2002 | 02:48 PM
Viken's Avatar
Viken
Keeper of the Truth
Post
<STRONG>thanks for the info but i really wanted to know if there is regular traction control like an M3 which i used to have.</STRONG>
The answer is no. From 2000 on, your only choice is PSM. No conventional traction control.
Old Jan 16, 2002 | 02:55 PM
bloke's Avatar
bloke
Post
Vikin,
thanks for the info. so no need to search endless in the manual.
Old Jan 16, 2002 | 09:19 PM
Speed's Avatar
Speed
Post
You should know that on the '99's traction control was an option not standard equipment. I don't have the option code handy for that year, but if the car has it it will be noted on the warranty book and on the inside of the front hood. Also, there will be a black switch with the letters "TC" on the dash since traction control can be deactivated.
Old Jan 16, 2002 | 11:19 PM
StephenB's Avatar
StephenB
Post
My 99 option code is 224 and also has the TC switch on the dash. It does help...I was on snow covered roads during the holidays.
Old Jan 16, 2002 | 11:56 PM
Dr. Z's Avatar
Dr. Z
Smile
Thanks for the explanation...I'm sure I will have more questions as I learn about the 996....
Old Jan 17, 2002 | 09:05 AM
bloke's Avatar
bloke
Post
Great since i know it doesnt have any kinda traction control. I be leaving the car home and taking the bus.
Old Jan 17, 2002 | 10:17 AM
JimB's Avatar
JimB
Post
Bloke, I'm not sure traction control is really neccessary. The one time I had to drive my C2 after a couple of inches of snow I was amazed by the traction provided by hanging the engine off the back bumper. Even with P-Zeros I had no problems getting moving. Stopping was a bit more exciting though.
