Do they make 18" snow tires that would fit my stock turbo twists?
Chandler!
Originally Posted by gota911
Riad - I did a search on Tire Rack and found nothing for 18" rims for your C4S Cab. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I have 17" snows now, but I bent the right rear rim and need a new rim and tire. But tire rack will not have the rim until late Feb... so I need to put my 18's back on.
Doh!
Chandler!
Originally Posted by kilrgt
Yes they do , I have 18" on my stock 18 TT II. I did go down a size in the rear, 265
Riad,
I reread your message and need to update my earlier response. I am not running stock turbo twists as I have winter wheels. I have a 2004 C4S with Pirelli 240 Snow Sports. The fronts are 225/40 18 and the rears are 265/35 18. The rears are equipped with spacers. This is the second season and I have found them to be very good. Let me know of any questions.
Chandler!
Originally Posted by C4S Surgeon
Problem is Riad's car has 11" rims on the back, that's too wide for a 265.
If you're interested, I may sell my winter rims and tires w/ spacers/bolts, let me know Rob.
Chris
Chris
Chandler!
Originally Posted by Mike C4S
for thr price of a nice set of 18in wheels and tires you can buy a winter beater and put the C4S away for the nice days.
I don't think snow tires are available for the 11" rear wheel. Porsche recommend a 10" wheel with a 265/35 tire. From the manual:
Wheel Enhancement would be a good place to look for the Porsche 47mm rear wheel. If you don't need a high end wheel, you might consider a reproduction:
Repros
I have no experience with these wheels.
Code:
911 Carrera 4S Summer tires Tire Rim Rim offset Track front 225/40 ZR 18 8 J x 18 H2 50 mm 57.9 in./1472 mm rear 295/30 ZR 18 11 J x 18 H2 45 mm 60.2 in./1528 mm or rear 295/30 ZR 18 11 J x 18 H2 63 mm (only with 17 mm spacer ring) 60.1 in./1526 mm Snow tires Tire Rim Rim offset Track front 225/40 R 18 88H M+S 8 J x 18 H2 50 mm 57.9 in./1472 mm rear *265/35 R 18 93H M+S 10 J x 18 H2 47 mm 60.0 in./1524 mm
Repros
Chandler!
Originally Posted by Paul Marangoni
Did you call Wheel Enhancement to see if they have the wheel you need?
Originally Posted by riad
Which brand did you get?
Chandler!
Riad I went with Goodyear Ultra Grip GD3's, I gotta tell ya they are great in the snow, and work well on the dry .I have to say they are the best performance Snow tires I have ever had..
