Not to be impolite but There is a tool in the kit behind the spare tire you can access the headlight assembly by pulling back the carpet in the truck the manual details this very clearly.
I believe a deep socket 10mm will do the job. Once you have engaged the nut turn slightly as it pops the housing out..it does not require multiple twists to remove it.
