996 Forum 1999-2005
Fabspeed 996 Airbox Upgrade
Old 01-15-2002, 07:06 PM
MKW
MKW's Avatar
Post
that wiring harness is 3/4 " thick with it's plastic protective sleeve - how could you even have bolted the two halves together ?- the screws wouldn't come close enough to seat more than a couple turns .
Old 01-15-2002, 07:13 PM
C4FDR
C4FDR's Avatar
Post
The harness has a loose covering that does flaten out to less 1/4" and the imprints were there.
FDR
Old 01-15-2002, 11:55 PM
ben in lj
ben in lj's Avatar
Post
"it shouldn't be unbolted for any of these box mods."
I mistakenly thought the Fabspeed box came with a new entire upper portion of the two peice airbox which would require moving the MAF.
fdr, it's going to be hard to tell until the MAF is replaced if they're telling you it might be bad. Once it is replaced, your problem may go away.
Old 01-17-2002, 01:57 PM
C2
C2's Avatar
Post
Can the airbox be used with the 02 C4S?
Old 01-17-2002, 02:04 PM
996FLT6
996FLT6's Avatar
Post
If the airbox of the new c4s is exactly the same as with the 1999-01 models then yes is the answer. Regards. Mike
Quick Reply: Fabspeed 996 Airbox Upgrade
