Hardtop fitment
Originally Posted by m5guru
The "socket" where the pin fits down into can be adjusted fore/aft, left/right, and up/down. I had a similar issue when I bought a hardtop from someone else for my car. I think it was a 17mm socket. If I recall, you need a wrench and a socket (deep socket?) to loosen the nuts that secure the hardtop receptacle to its mounting plate.
David
David
Tell me if this sounds right.....I'll assume that youe would be loosen the nut on the bottom (an open-end would work there).....then use the socket on top to snug it and probably keeping track of # of turns or whatever. Unfortunately, then you really don't know where you are at until you put the top on and have a look-see on fit.....and may have to remove and go through process again.
Make sence?
