Performance Upgrade
I have a 99 C4 completely stock. I would like to boost the HP a bit... What is the best way to go about it? Are there performance chips available for these cars? How about air intakes and free flowing exhaust? I don't want the car to be really loud though...
Thanks!
SPT
Thanks!
SPT
My 99 was also completly stock when I got it. I added the
Fabspeed 996 Maxflo Performance Airbox Enhancement Cold-Air Kit and The K & N Filter which means that I:
Took out the muffler inside the lid of the stock air box and installed the carbon fiber block off plug.
Removed the black hose that goes to the throttle body and installed the smooth red silicon hose. Removed the plastic screen and the metal screen in front of the Mass Airflow Sensor in the air box and installed the carbon fiber ring in its place.
Removed the stock air cleaner amd used the K & N air cleaner.
Fabspeed says this gives 25% more air flow and .42 seconds faster acceleration.
I installed the 996 Fabspeed Maxflo Free Flo Mufflers with the Chrome sport oval tips.
Fabspeed says this gives +10 HP
I think this combo did give me more power as it sure feels like it and the intake sounds great and the exhaust sounds awesome.
Installed the B & M Short Shift also
bob
bob
I guess SPT has a question regarding headers. I don't know why he chose to send a moderator alert for it, though. Here it is:
A user (SPT at IP 24.62.72.145) has requested that you review the
following post by SPR in a forum you moderate:
headers and chip
The user's reason for this request is:
Don't I already have headers??? I thought all 911's had headers...
You may view the topic at the following URL:
<a href="http://forums.rennlist.com/cgibin/rennforums/ultimatebb.cgiubb=get_topic;f=5;t=004393;p=1#000001" target="_blank">http://forums.rennlist.com/cgibin/rennforums/ultimatebb.cgiubb=get_topic;f=5;t=004393;p=1#000001</a>
headers and chip
No - they do not have equal-length headers. You can get a set from Fabspeed. Add their Piggy-back computer. My 99 996 gained 26.5HP neasured before/after on the same dyno/same day. I have to admit I'm thinking of purchasing a 2003 but if I do, I'll transfer the headers and computer. Dealer had no problem at all with the headers - the computer is electronically undetectable. I highly recommend these two items.
I have an 01 C4 with GHL stainless steel exhaust and headers. Air flow and heat transfer are improved for increased torque. Sounds great. I hear that chips do not offer much. I had the ecu reprogrammed to ROW which makes the torque band more linear. A light flywheel would also increase torque.
Regards,
Mike
Regards,
Mike
giac and gemballa chips give 23 hp, not much? dunno also high flow cats give some also but the best bang for the buck, after reaearch would entail headers and chip. other stuff is afterwards, cats, bmc, mufflers, throttle body, etc.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by MikeP Long Island:
[QB]No - they do not have equal-length headers. You can get a set from Fabspeed. Add their Piggy-back computer. My 99 996 gained 26.5HP neasured before/after on the same dyno/same day.QB]</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Did you purchase a preprogrammed piggy-back or custom tuning at Fabspeed?
Could you comment on the piggy-back setup (i.e. where does it mount, how many wires are attached to the car, etc).
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by NMoore:
<strong>A lighter flywheel should be more free-revving at the expense of low-end punch.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Why would you loose any low-end punch with a lighter flywheel?
I had the Piggy-back installed/programmed by the Dyno facility used by Fabspeed. This was nearly 4 years ago. I was there during the entire process. The computer is installed adjacent to the car's OBDII computer which is underneath a panel in the back seat area of the car. The computer is wired into the car's harness - probably 10 wires or thereabouts - so cutting/soldering is required. As I mentioned, the piggy-back is not detectable electronically. However, if, for some reason, the dealer had to physically access the OBDII computer, the Piggy would be obvious. Of course, since my 99 is out of warranty, this doesn't matter at all. And it didn't matter to me then, obviously. The car wasn't more than 6-8 months old when the piggy/headers were installed. (I installed the headers and posted all the pics on this site way back then.) This is my first visit to the Rennlist in nearly 2 years!
After dyno programming, the car was tweaked in actual driving on the street by the dyno operator. He sat in the passenger seat with the laptop still connected to the piggyback and made minor adjustments at all driving ranges from idle to acclerating at WOT. I was/am still extremely happy with the results. Consider that the 26.5 HP and additional torque through the rev range means your 99 will have more power than an unmodified 2000-2003 996.
Bottom line is that on a naturally aspirated Porsche engine, there is not a whole lot you can do to tweak extra power without spending $10K+.
You can do the chip, exhaust, headers, and air intake, but you will have spent $5,000+ and gained only about 25-40 HP (aka not noticeable). The law of diminishing returns certainly applies early on with these engines. You can supercharge the engine, but that will be at least $6K-$8K by itself.
Now the 996TT on the other hand...$500 for an Upsolute Chip, $1500 for a custom exhaust, and $100 for a K&N - BAM! You've got an easy 80-100HP+.
