HELP! Brakes look rusty
I just gave my 03 cab its first wash.
The brake discs have this awful rusty brown look on them!!! They didn't look like this before the wash.
Is this normal?
thanks
Chucksta
Is this normal?
thanks
Chucksta
NORMAL -- NORMAL -- NORMAL
Here is the TSB about it...
"911 (996)
4/02 4650
7/22/02
Binder Group 4, Running Gear
Corrosion on Brake Discs
Vehicle Type: 911 Carrera (996)/911 Carrera 4 (996)
Model Year: As of MY 1999 (X)
Concern: Corrosion on the brake discs.
Information: Due to inquiries regarding corroded brake discs, the following text will appear in the vehicle Owner's Manual as of Model Year 2003.
The following text can also be helpful when discussing corroded brake discs with customers.
To prevent corrosion of the brake discs, "brake them dry" before parking the car. Even though the brake discs consist of alloyed grey cast iron, they will unavoidably start to corrode if your car is parked for an extended period. The brakes will tend to "rub" as a result. The nature, extent and effects of corrosion depend on the amount of time the vehicle was parked, whether granular or liquid road salt was spread and whether grease dissolving agents were used in car washes. If the braking comfort is noticeably impaired, we recommend having the brake system checked by a Porsche dealer."
"911 (996)
4/02 4650
7/22/02
