996 Forum 1999-2005
Tip Control Unit and ECU Software Change
Old 06-05-2003 | 12:19 AM
boca996's Avatar
boca996
Question Tip Control Unit and ECU Software Change
I have a 2002 C2 Tip and have heard there is a software change to the Tiptronic control unit, and another for the ECU (engine control unit). Does anyone know anything about this?
Old 06-05-2003 | 02:15 AM
Loren's Avatar
Loren
Post
There is a TSB for torque converter lockup problems for cars produced before October 2002. The TSB number is: 6/02 3701 Tiptronic Transmission Noises.
It is a new control unit which includes software. If you are having problems then you should talk to your dealer.
Old 06-05-2003 | 08:39 AM
boca996's Avatar
boca996
Post
Thanks Loren,
How do I know if my car was produced before October 2002?
Old 06-05-2003 | 12:42 PM
Loren's Avatar
Loren
Post
On the edge of the drivers door is a sticker that has the month and year of manufacture.
Old 06-09-2003 | 01:21 PM
redcab's Avatar
redcab
Post
Does this TSB apply to MY2001 (and earlier) cars?
I know the MY2002 had some significant changes.
-jerry
Old 06-09-2003 | 01:47 PM
Loren's Avatar
Loren
Post
Jerry,
No, the TSB is only for MY02 and newer cars. The Tiptronic in MY02 is quite different from earlier Carrera models. In MY02 they started using the TT Tiptronic (model A96/50) for the added HP output of the 3.6 liter engine.
Old 06-09-2003 | 03:51 PM
sharkster's Avatar
sharkster
Post
Hey Loren, this doesn't apply to the 996TT does it? Thanks..
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Loren:
<strong>Jerry,
No, the TSB is only for MY02 and newer cars. The Tiptronic in MY02 is quite different from earlier Carrera models. In MY02 they started using the TT Tiptronic (model A96/50) for the added HP output of the 3.6 liter engine.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">
Old 06-09-2003 | 04:32 PM
Loren's Avatar
Loren
Post
Yup... the TT TSB is:
TSB 5/02 3701 (dated 2/14/2003)
Tiptronic control unit adaption of the torque converer lockup.
and it applies to TT cars As of MY01.
I'll send it to you via email...
Old 06-09-2003 | 04:52 PM
sharkster's Avatar
sharkster
Post
Thanks Loren you rule.
<strong>Yup... the TT TSB is:
I'll send it to you via email...</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">
Old 06-09-2003 | 06:36 PM
redcab's Avatar
redcab
Post
Thanks Loren !! <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
The tip transmission hesitation that I've complained about before seems less pronounced when I step on it a little more forcefully.
I've noticed that if when starting off in 2nd with a moderate jab, the 2 - 3 shift happens in that same 2700 rpm range, effectively giving a good reason for the brief hiccup.
Does Porsche publish the tip shift maps?
Quick Reply: Tip Control Unit and ECU Software Change
