B & M Shifter
10:00 we start filming. Hope you 996ers have good rear main seals so you do not leak oil on Henry's driveway. Jeff
<a href="http://www.babblers.org/board/main.pl?read=26917" target="_blank">http://www.babblers.org/board/main.pl?read=26917</a>
Member - times 3
Member - times 3
Bob,
How much lower is "much lower"? Mine didn't seem noticeably lower. I didn't measure the new vs old shifter, but the distance from the bushing to the tip of the lever in Jeff's pictures does not look like 2". If you've raised your **** 2", doesn't that defeat the advantage of a short shifter? (At least you still get the better hardware!).
Hey Jeff, is the B&M any shorter? Could you measure a pair next time you are putting one in?
Patrick,
The B&M is the same height... I'm sure.
Jeff,
LOL... I think I've installed B&M's in all the other 996's in the aera!
If Chad's PSE arrives we will install that also. We will likely do a mod to Chad's air cleaner while we are at it.
Jeff,
Yes Patrick they are both the same height but on the B & M I raised the shifter handle 2 inches after pushing it down all the way. The throw is still much shorter than the stock shifter with the **** pushed down all the way. With my **** a little higher on the B & M it just felt better to me, less effort to push into gear but still a much shorter throw and very percise. I love how it clicks into gear.
bob
bob
If you 996ers want us to take pictures on Sunday of some special applications let us know. I will even bring my ruler.
The last picture was a joke. There is no B&M in that car. Danny, a local Boxster owner, cut down the flat blade of the oem shift lever and put on an after market shift ****. Poor man's short shift. Jeff
Member - times 3
Member - times 3
I have to agree that the feel of the shifter is much better than stock!
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Bob H:
<strong>Yes Patrick they are both the same height but on the B & M I raised the shifter handle 2 inches after pushing it down all the way. The throw is still much shorter than the stock shifter with the **** pushed down all the way. With my **** a little higher on the B & M it just felt better to me, less effort to push into gear but still a much shorter throw and very percise. I love how it clicks into gear.
bob</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">
I'm excited, I'm going to get my shifter installed on Sunday.
Courtesy of Tool Pants, Loren, Aileen et al, with a special mention to "Henry".
I tried one at an autocross last weekend and just had to have it
Tool Pants, when will your DVD be available to buy? Scott
