Sideskirts Mk1 vs MK2
Hi everyone my first post here...how do you fit the side skirts? is it easy? someone maybe got some pics of it or a link, is it the the same for mk1 as for mk2 ? must i have the frontbumper installed if i have the skirts on, maybe look strange without it who knows..., and at last is there front lip that fit under the standard bumber ( 99 ) so i can get the front a litle lower...
/Robert
/Robert
Hi, and welcome. The sideskirts are not hard to install with two people (you will need an extra hand). Use 3M molding tape along the top edge, and there is a mouting kit with clips for the bottom that you can buy from your local dealer. As for the front bumper, Getty Designs has an add on lip but I've never seen it on anyone's car before. Maybe someone here has one and can post pics. Automotion.com aslo has one I've never seen mounted. I was considering both myself and just went with a complete bumper instead.
Welcome Robert. The sideskirts will look incomplete without the front spoiler to match. The sideskirts are fairly easy to install. You will need to clean the surface where the sideskirts will go on really good then heat up that area but DO NOT overheat. Once the surface is warmed up, stick the sideskirt on and hold until you know that its on good.
Now lets see your 996.
Robert, I have a bunch of pictures of both side skirts. I'll try and post them later. if you can't wait you can check these links.
http://www.funcarsonline.com/gallery/Itzkirb
and here
http://gallery.rennlist.com/gallery/albur17
and welcome to the board, this is a great place.
and here
