B&M SHORT THROW SHIFTER INSTALL?
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
ARE THOSE THINGS HARD TO INSTALL FOR A MECHANICALLY CHALLENGED PERSON? I DON'T WANT TO SCREW UP ANYTHING IN THE CAR.....
HOW ARE THE INSTRUCTIONS THAT COMES WITH THE SHIFTER?
I SHOULD BE GETTING IT END OF THE WEEK..
PETER
PETER
One of our local Boxster owners, Aileen, has done so many B&M installs she can do it blindfolded. The instructions are ok but they do not tell you to mark the shift cables before you remove the shift tower. You must mark the locations of the cables before you remove them so that when you put the tower back on and hook up the cables they will be in the same location when you started. Jeff
<img src="http://www.986host.com/albums/ToolPants/B_M_at_Henry_6_8_024.sized.jpg" alt=" - " />
<img src="http://www.986host.com/albums/ToolPants/B_M_at_Henry_6_8_008.sized.jpg" alt=" - " />
