My Radio stays on when I turn off my 00 Cab
The radio used to stay on when I turned the key off, and would finally turn off when I actually pulled the key out of the ignition. I assumed this was normal.
Now the radio stays on even when I pull the key out and get out of the car. I now have to turn the radio off each time.
Anybody heard of this?
Maybe you could clarify that a little. My radio always used to shut off. Now it doesn't no matter what. Unless I manually turn it off. If I don't touch any *****, it still stays on.
Oh, then there does seems to be a bit of a problem. Have you searched on this topic? I am sure somebody has had this at one point or another.
BTW, is that your 356 in the avatar? Very nice!!!
My 02 C4S does the same thing, I dont think it's a problem, it's a more of a nuisance. Have you waited to see how long it will stay on? I believe it will go off in 15-20 min but I can't be sure. I just get used to turn it off manually
I had the same issue last night, radio stayed on... used to always shut off after removing key, and/or opening door. Maybe something to do with ignition, but it seems like a longshot?
I also have a 2000 cab, I had this same problem. My problem was the ignition switch was going bad. I first noticed when the radio didn't shut off, then the key got harder to remove. This seems to be a common problem with the older ignition switch. If you do a search on renntech you will see people have had all sorts of strange electrical problems as a result of this switch. Hope this helps.
mine stays on after key pulled for about 10 sec once the door is open. if door is still closed, i think the radio keep going without key in. my is a 02 cab.
try removing the face plate on the stereo and perhaps resetting the radio somehow.
