Why do I feel like I'm floating?
#47
got a 99 911/966 cab and find the front also very light....scarry almost....car handles perfect..but the light floating feeling, gives me a very insecure/unsafe feeling. Luckily driving over 100 in LA without getting pulled over is almost impossible...so the floating feeling keeps me in check.....have to say that my Honda Element feel better/safer at 90..but I won't make the same lane changes as with my P.
#48
I have a 99 C2 with stock suspension and 17" rims. I haven't felt any floating in the front end, and I've been to 130mph. In fact, it felt very secure travelling at that speed. I feel very secure in my 996 no matter what the conditions and speeds I'm going.
#49
Lightness plan of attach
From reading all the posts here, and my own prior experiences with other cars (yes, I have noticed this sensation before), I am left to presume that perhaps:
1. I still have those damn Continental Contisports 2s on and they are the reason that the car tracks lightly at speed (yes, I know, not likely and a carry-over from another thread on Rennlist recently, but I hate these tires).
2. The tire pressure is creating the disturbance. However, Dirtrack49 stated that he has tried varying pressures to no avail or alleviation of the problem.
3. Alignment is required. I must say that I am leaning to this solution. As suggested in a post on this thread, adding burrs during alignment might be the solution because these cars can go out of 'line' often, particularly if you drive on poor quality roads like in NYC. I will be scheduling this post haste. I bet this offers salvation.
4. Suspension modifications. The RoW M030 might be a decent solution. I can accept that minor changes in frame geometry and pivot points caused by lowering the car would improve handling. However, I don't know if that would be the cure to this problem, even if it did resolve the symptoms. It just might push out the 'lightness' sensation to higher speeds. My goal is to resolve/cure it completely. Besides, I have driven cars that had the stock USA non-sport suspension and they drove as expected.
5. Aerodynamic modications with bumper replacement. I don't by this at all. The sensation happens at speeds as low as 70-80 mph. If it only happened at 140 mph, I would say that's the nature of the beast. Oh yeah, I also know this isn't the case because I ALREADY have the Aero I front spoiler and side skirts.
So there it is. Alignment imminently, and then maybe RoW M030 suspension upgrade anyway, and I'll post back and let you know how it went. Of course, it still could be those damn Contis.
Cheers,
Edward
#50
MkI front and skirts (Aerokit) and RoWM030 totally transformed my car. Feels like it should. Floating feeling? Gone. Light feeling? Gone. SUV look? Gone.
#51
A few weeks ago , I started getting that lightness/bouncy feel at speeds, esp on the track. I had my alignment checked, it was a little off, as the car had settled about another 1/2" since my X73, and created some significant toe out. Taso at TPK Performance(formerly RPM) re-aligned it, now it's perfect once again!
Def check the alignment first.
#52
Dell, you are a riot. SUV look? Come on, it's not that bad.
Anyway, I think the alignment is definitely the right start. But hey, if not....then what a wonderful excuse for some Euro spec suspension hardware. I tell you, you guys on this forum are going to be the death of me and my wallet. BUt then again, money's only something you need in case you don't die tomorrow.
#54
Originally Posted by JimB
Tom,
As you'll come to expect, you've received some great advice here. I drove a students 99 996 with the stock suspension at Brainerd a couple of weeks ago and it really didn't start floating around until around 130-140. 120 through T1 felt great for a stock car with street tires. The car in stock form is really incredible.
As other have suggested, I would attack the issue in this order:
1) tire pressures/tires in general
2) alignment
3) suspension. which one depends on what kind of ride you're willing to live with
4) aero kit. I would do the suspension first only because it has other benefits
5) more suspension. by now you will be addicted. welcome to the slope
Have fun.
Jim
2) alignment
Have fun.
Jim
check the tyre pressures.....(in fact adjust the tyre pressures....)
as dirtrack49 sais try something "crazy" . from the factory recomendation of 36psi fronts, 44 psi rears, to any combination down to 30 fronts/36 rears.
i had excactly the same prob....i went from stages 2-5 as above....and stage 1 with the factory settings of 36-44...i thought i was perfect and something else was wrong.....
then someone told me " take off some air!!!!"
now i am running 32-36....and....
i am pleased....try it
#55
you know what??? I still enjoy driving my P..with all the "problems more than any other car I ever had...the cornering makes up for the "floatiness" and with all my photo equipment in the trunk....the car handles like a dream...cheapest solution...put a 50 pound weight in the trunk...slows you down a little but the floatiness is gone....
#56
why would you do that...
there is no reason of choosing this way...
identify the prob....solve it and you will be still enjoying the car without any prob....
#57
I recently changed my very cold tire pressures to 35 front and 42 rear. The lightness handling sensation is improved to some degree...enough so that I may experiment with different pressures, perhaps going to the 34/40 config mentioned earlier in the post.
I will say that I think that the Conti tires, if not the source of the problem, definitely exacerbate it. They just sound so awful on asphalt and concrete as though they are out of round. I know it is not a balance issue, but clearly, I will replace the tires after the thaw (that's spring here in NYC) and rebal and re-align. I suspect this will resolve all issues for once and for all.
Anyone been able to fix the lightness sensation without going to the RoW euro-spec suspension?
#58
