996 Forum 1999-2005
H&R SPRINGS DROP - NOT HAPPY.
Old 09-18-2005, 09:33 PM
SPIKES
SPIKES's Avatar
Default H&R SPRINGS DROP - NOT HAPPY.
i did the swop today...what a job but actually not that bad. the rear droppped nicely from 26.5 to 25 inches. (stick 1 finger between tire and fender)
the front dropped from 26.5 to only 26. the front does not look nice and the car looks nose high. (about 2.5 fingers from 3 fingers)
i only did the h&r springs with my stock shocks.
did i do something wrong ?
any suggestions?
thanks
Old 09-18-2005, 09:39 PM
leedav
leedav's Avatar
did you drive the car to settle it?
Old 09-18-2005, 09:56 PM
SPIKES
SPIKES's Avatar
yes. i have settled it. i have driven the car at least 30 miles and was hoping it would settle more.
Old 09-18-2005, 10:49 PM
kilrgt
kilrgt's Avatar
First time i have heard of this.....it takes longer then 30 miles to settle...give it a little more
Old 09-18-2005, 10:54 PM
LVDell
LVDell's Avatar
I got much more settling in my setup (RoWM030) after several tanks of gas and a hard DE event. Trust me, 30 miles ain't gonna do it!
Old 09-19-2005, 01:42 AM
TT Surgeon
TT Surgeon's Avatar
let it settle, my x73 took a while.
Old 09-19-2005, 02:02 AM
TallCoolOne
TallCoolOne's Avatar
any suggestions?
thanks
Did mine last week and have no problem with it other than I needed to roll the rear fenders
Old 09-19-2005, 10:26 AM
dallasboats
dallasboats's Avatar
Go find some RR tracks and jump the car. You'll need to get at least 6.7' of air to settle the car correctly. Once finished jumping, the car should ride nicely on the inner fender wells with sufficient rubbing. You will have no fender gap and the car will look really cool. Good luck and wear a helmet.
Old 09-19-2005, 12:55 PM
Chads996
Chads996's Avatar
Correct-a-mundo all. You will need to ride on them for a good solid 100 miles for them to properly settle at the very least. Be patient. They will look great.
cheers,
Chad
Old 09-19-2005, 01:40 PM
evo_333
evo_333's Avatar
yup, needs to settle...
Do you have any pics of the car w/springs? It may be easier for people to evaluate your issue, if there is one
Old 09-19-2005, 03:10 PM
SPIKES
SPIKES's Avatar
thanks for all the replies. if it makes any difference i bought the springs used from a fellow rennlister. do they still have to settle or does the car settle?
Old 09-19-2005, 03:12 PM
LVDell
LVDell's Avatar
Roh-Roh! That changes everything.
Old 09-19-2005, 03:24 PM
wlee69
wlee69's Avatar
Couple things you could check as I just did mine about 2 months ago (but with new shocks also)...make sure that you have the spring perch facing the right way and that the springs are sitting on the perch correctly. The other thing to check is to make sure H&R sent you the correct springs for the front...it should be stamped on the side of the spring and you can check on-line to make sure they are the correct ones....
When I did mine with the new shocks, it was a consistence drop between the front and rear.
Old 09-19-2005, 03:35 PM
SPIKES
SPIKES's Avatar
thanks...the numbers are correct. we did the assembly very quickly...slide off..slide on..maybe something is not seating properly. i am going to have to pull them off again and check....i might even be tempted to CUT them slightly
Old 09-19-2005, 03:37 PM
SPIKES
SPIKES's Avatar
ok...so i assume the springs settle and not the car?
Quick Reply: H&R SPRINGS DROP - NOT HAPPY.
