running a 295 rear temporarily with a 285 a problem?
I had a blowout recently where it caused me to replace the right rear. Since I need to replace the other tires as well and certainly must replace the right rear, I wanted to get a set of ps2's. As such I ordered a set of 235/295's. since I am in SD and I want other things done this thursday in LA and need to put a tire on the car, I had the one 295 sent to me.
Ok, so now that, that is over, Will it be bad if I were to drive the car with a 285 on the left and a 295 on the right? I have a limited slip diff and that is my main concern. Any issue? I am going to drive the car up to LA, but need I only limit the time driven to that or is it ok to drive around with the car in the meantime? Thanks Sean
Anyone??? btw the diameter difference is less than .2 so I wouldn't think it would be a big deal. Please let me know so I can either enjoy my car over the weekend or refrain. Mainly I am worried about my diff.
I wouldn't drive it because of the LSD -- seems like it would but a lot of wear/stress since it would be slipping all the time due to the tire diamater difference.
well wouldn't it be the same argument with the spare? I highly doubt it is exactly the same radius as my 285 that's on there now???? I hear you on the concern though that's why I am inquiring before I put any miles on it.
If there is a choice, I would rather NOT run with two diff sizes. If you were forced to, then the difference is small enough I'd say do it.
I don't get one thing, though. Why have only ONE of the rears tires shipped to you? Why not ship both and have both rear tires replaced?
I didn't think about it really. I had the blow out and the first concern was to replace the blown tire and have the rest sent to Lucent to have them mount them, as the discount tire here sucks for balancing.
btw I found out the diameter of the spare it is actually .05 off the 295 diameter, making me think it won't be a big deal. I also did some other research and the only issue is to turn the traction control off.
