Wing problem solved! I Gots me one
Thanks to all who replyed to my post about purchasing one. I ended up buying a Misha GT2 wing for the slim hip....Just wanted to say I'll post pics once its here and on the car.I will be asking for some tips to install it when its ready.Thanks Dan ( Vivid Racing) for hooking it up.....
I love my Misha wing, but be sure to get the front splitter if you can or lower the front end or you may get some buffeting from the front end lifting as the rear has more downforce at high speeds. I used the GT2 front end and it is very stable at 165 plus. Will
Kirbs still not in my hot little hands, The second its on the second you all will get pics, Any tricks to installing it? What happens with the wing light on the cluster , does that need to be bypassed some how.
I went by Kirby's step-by-step instructions, and it installed perfectly.
Thanks for the tips, Kirb. It would have been a bitch without your photos and instructions!
Good Luck -
Gregg
Good Luck -
Gregg
Good Luck -
Gregg
Good Luck -
Gregg
Glad it helped you! Love it when I can help someone out!
Misha Wings come in pretty good shape...it's not perfect but compared to some other companies it's at the top in quality.
I've done 3 wings so far including mine and all have fit perfectly. Of course the paint match and stuff is dependant on the bodyshop you use.
Hey Kirby
Is there any bypass harness for the wing light in the cluster, I am not even sure i need this, I just thought that if it thinks there is no wing there it would blow a code, Is this the case??
When you disconnect the motor, there will be these two microswtiches. These microswtiches are what triggers the motorized wing to raise and lower at speed. I just tiestrapped those microswitches down and so far no spoiler warning light.
There is also a bypass harness that you can buy from the dealer (or us). It usually comes with the Porsche Aerokit since you need to remove the motorized wing when you put it on. Off hand I do not know the harness part #. I know this was mentioned before and you can doa search for the Harness or try searching over at Renntech.org for the part #
