H&R SPRINGS DROP?
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Originally Posted by mbergeron
Nice garage...what kind of floor covering did you install ?
Thank you.
It's an $60 Epoxy Paint Kit that I got from the local hardware. I'll look at the box when I get home, but it's pretty good. Highly resistant to tire marks and oils. 1 kit is good for 1 car agrage so I bought 2 which was more than enougn for my 16X24 2 car garage. It comes with the chemical to acid clean the concrete and a video on how to do it. It also came with those spreckels that you're suppose to spread, but I like the plain gloss gray "clean" look.
Not as nice as this guy http://www.hooville.net/forums/showthread.php?t=64
The brand of the paint is RUST-OLEUM, EPOXY SHIELD, GARAGE FLOOR COATING. Like I said earlier It's a $60 Epoxy Paint Kit that I got from the local hardware. I'll look at the box when I get home, but it's pretty good. Highly resistant to tire marks and oils. 1 kit is good for 1 car agrage so I bought 2 which was more than enougn for my 16X24 2 car garage. It comes with the chemical to acid clean the concrete and a video on how to do it. It also came with those spreckels that you're suppose to spread, but I like the plain gloss gray "clean" look.
Originally Posted by teflon_jones
I also did the H&R springs, but in a C4. They dropped it about 1.5" all around. Great mod, improves handling and gives the car a much better stance.
Sorry about the fuzzy terminology, but I seem to recall a talk at a BMW club event that inferred something like this? I think that the net effect of putting shorter springs on stock shocks is that the car gets "bouncy" (lots of oscillations) after hitting a bump?
David
Originally Posted by aben8057
Mike, nice garage
Originally Posted by m5guru
Aren't shorter springs supposed to be matched with different (I'd assume stiffer) shocks? Otherwise, don't you end up at a different "rest position" of the stock shock which changes the dynamics of the shock?
David
David
