0-60 with stock set up, how fast?
#31
Originally Posted by neil.schneider
Doug,
Maybe I'll get one. Thanks for the warning about the clutch.
You can check out where I mount mine over in the G-Timer thread from a couple days ago.
#33
Originally Posted by mdillian3690
So how much slower whould you say a C2 Tip is? 0-60mph? 300hp!
Porsche's website claims 0 - 60 of 4.8 seconds for a manual 997, and 5.2 seconds for a tiptronic. The differential is probably similar for a 300 hp car.
#35
1 Post
No "save it for the track" sermons or the "Porsche is not a 1/4 mile track car" rule?
The hardest part is the launch, IMO which I haven't had time to practice.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Originally Posted by Carrera Mike
I've read that the 5.0 sec 0-60MPH is conservative data from the factory. How much quicker than 5sec have you guys ran 0-60 with a stock set up? I know it all comes down to the driver's shifting talents.
#36
Originally Posted by arenared
I use mine all the time to check tire pressure, alignment, swaybar settings, tires, brake pads, etc., etc.
EDIT: forget it. you probably mean that you use the G-timer to measure performance after you have changed pressures, tires, etc. My fault. Ignore me.
#37
EVO magazine tested a 3.4L C2 at 4.6sec 0-60.
My car, a 99 C2, has 17" wheels and it feels very fast from a stop (or a roll, for that matter). People don't realize how much of an effect wheel weight has on peformance.
It is much more than just the extra total weight of the wheels, it's the increased Rotational Intertia that basically robs you of your torque. Not only that, but when you "upsize" your wheels, the weight is concentrated further away from the rotation center than before, and increases the effects even more. Same goes for tires- some tires weigh considerably more than others of the same size. These extra few pounds are located far away from the rotation center, so the weight effect gets really amplified.
Keep this in mind when you are blinging down the road in your 19's. People think that a few pounds don't matter, but they really do!
#39
Originally Posted by gravedgr
Unless I'm at the strip, I'd rather look good and be a quarter-second slower. ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
I agree - but actually, I would want to have both.
I'm going to get some 18" wheels in the next few months, but they have to have all the goodies: looks, strength, and light weight. Of the types out there that have them, I'm leaning toward the BBS line and they are right around 20lbs or so.
#40
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
I used to tune helicopter main and tail rotor blades. 2 ounces of balancing washer(weight) equates to several lbs of weight when rotating at only 298rpm
