Unstable on wet roads
Tires have only around 3-4000 kms. thread depth looks OK to me. Sounds like I need to go back to a store and get allignment checked again.
Thanks for hints. Will post results later.
Hydroplaning. 130 k/ph with ANY standing water is a likely scenario. The car is traveling on some pretty wide rubber. These cars only handle like magic when on dry pavement and semi magical when wet. If I get caught out in the rain; I age 50yrs and go SLOW, I don't want to wad my car up. They are fun to hang the rearend out when it's damp.
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
Originally Posted by 1999Porsche911
If you are running good quality tires, rain does not effect the handling of these cars much at reasonable speeds. Standing water is another story.
DO tell , how rain does not effect how a car handles?....
standing water?.....When did you get the stupid idiot award?...and when did you master it?...
OK. Back from allignment shop. My values were way out of whack...!!!!! So much toe-in on my back axle must have created this handling behaviour. How did they change so much is a mystery. have not tried on wet yet. Am eager to see how the car handles on wet; on dry it turns in faster. One thing though, wheels produce less road noise.
Does anyone run toe out on rear and toe in on fronts?
