P/N # Engine Protection Plate
07-22-2005, 01:07 PM
To all:
I am looking for the part number for engine protection plate for 01 C2.
Thank you in earnest.
07-22-2005, 01:26 PM
07-22-2005, 01:38 PM
Would this be needed on a 2003 C4S, or is it for earlier models primarily?
07-22-2005, 01:39 PM
good point. not sure of the P/N now..got it from JimPDX.
07-22-2005, 01:49 PM
More needed for the 99-01 models with the RoWM030 suspension but a great addition for ALL 911s. 99-present
996 107 981 00
Got mine for $80 from Sunset
07-22-2005, 01:56 PM
Dell, How much does it weigh?
07-22-2005, 02:04 PM
I would say less than a pound. No real wieght to it. More protection than anything.
07-22-2005, 02:24 PM
07-22-2005, 02:28 PM
Less than 5 minutes. Remove 3 bolts and re-insert them with the plate in place.
07-22-2005, 02:33 PM
do you have to take it off to drain the oil? Or is that hole in the center the oil plug
07-22-2005, 02:34 PM
07-22-2005, 02:48 PM
Are there any disadvantages that you know of by utilizing this plate? Such as not identifying oil leaks, which would be identified w/o it.
TIA
07-22-2005, 02:57 PM
If you are referring to RMS, then no. Not anywhere near it.
07-22-2005, 04:11 PM
Quote:
Hi Lee...
probably about a pound.
07-22-2005, 04:16 PM
Quote:
TIA
there is a small issue with the plate which is very minor. when changing your old you have about 1/2 inch less clearance because the plae extends about 1/2 below the lowest point of the pan. I set my car up on some wood boards when I change the oil to compensate.
if the issue about hiding any oil leaks is of concern to you you can pop that puppy off in about 30 seconds. Its just three bolts holding it on.
