Evoms Intake, Fabspeed exhuast and Chip Tuning Update
Interesting to look at this EVO dyno picture...
http://www.evoms.com/porsche%20ec%20art%20test.htm
Note the OPEN decklid... Hmmm...
Originally Posted by itradem
Carlos,
Any luck in "opening up" the airbox yet? I am running the exact same set-up, so I am interested in your findings... Have you talked to Todd at EVO?
my solution is coming tomorrow
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
looks like you are halfway there, you already have the decklid!
haven't talked to todd@evoms. my earlier thread was also posted on 6speed (where i think they mainly hang out) but he didn't reply. i need to find out if their dyno results were based on an open engine bay.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Carlos,
I'll take a look at my decklid tonight and ponder on things...
Just a thought, but I wonder what would happen to the dyno numbers if you blow air into the stock air intake location with the decklid closed??? If you are not blowing air into this intalke, I'd assume that you are creating zero "venturi force," and not simulating real world conditions... aka the air flow from the car moving???
Any thoughts?
Any thoughts?
Originally Posted by 1999Porsche911
Just turn your engine compartment fan on. Brings in more than enough cool air.
that won't help the vflow.
when the engine lid is closed the vflow is sealed and it can only draw air from the stock air intake location/opening. if you can open up the area around the cone filter then the vflow can draw in huge amounts of air from the stock opening AND then new opening. i will take pics once i have the decklid cut apart
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
1999Porsche911,
I may be an idiot here, but how do you turn this fan on manually? Is there a switch somewhere? Sorry if this is a dumb one...
Install a switch and connect to the ground side of the fan relay. Easy on/off.
when the engine lid is closed the vflow is sealed and it can only draw air from the stock air intake location/opening. if you can open up the area around the cone filter then the vflow can draw in huge amounts of air from the stock opening AND then new opening. i will take pics once i have the decklid cut apart![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Oh yeah...the new one is sealed so you do have the benefit of only getitng cool air into the intake rather than collecting the hot engine air with just the filter laying there.
Sounds similar to a switch I had installed on my 94 RX7 TT... THAT engine would run hot, and you needed to be able to cool on comand... thanks for your help...
I have my engine compartment fan and both radiator fans hardwired. Makes a big difference riding around town.
Carlos,
Any thoughts?
Any thoughts?
