Pics Attempt
Pics Attempt
When I joined I neglected to post any pics. The car is dirty, but I got a new lens and was trying it out. Thanks to LeeDav, who between puffs on a cigar helped me out. I am going to get my wife a.k.a. Einstein computer geek to give me a tutorial on picture posting. Here goes........
It is working on the preview, I'm pushing submit.....
Newbies Hospitality Director
I am running coilovers. The rear is at 24.75". My suspension and alignment are as agressive I can go without risking dental, spine and car body damage. I am careful around speedbumps and steep driveways.With the GT3 sways I have been able to get the car to neutral. The setup is not a hinderance and the car handles fantastic. I would be lying if the drop was also not cosmetic. Thanks for the compliments.
Would the addition of side skirts look good?
Originally Posted by gota911
John, Yes, they would look GREAT! In fact, that is going to be my next MOD! I am going to go with the OEM side skirts, because I like the rounded profile better that the more angular, creased look of some of the other side skirts.
Which are the rounded ones. I would like skinny at the front and wide at the rear. I need all the help to put a fat a$$ on this Kate Moss car.
TD
Originally Posted by TD in DC
I disagree! I would get the generation appropriate ones (see mine) that match the lines on your front bumper. The side skirts make a huge difference and the give the 996s a "presence" in my opinion. Very nice car . . .
TD
TD
I think you put the lwr lip on the bumper. Are your side skirts the ones I need? I achieve more than 150 mph on the track and don't want anything to turn my car into a plane. The way it is now it really settles down after 85 mph and is stable.
I will get the ones for the '02. If I order from Porsche I assume they are unpainted. Didn't you clear bra yours after paint? If they were only $300-$400 I would have them Line-X'd the car color and if they didn't match; start over. I am going to see if the shop that Line-X'd my truck can match and do the extreme lwr portion of my bumper. Not as cosmetically as clear bra, but it is durable as all get out.
The areas that tend to pick up chips are, as you would expect, immediately behind the front wheels (basically the flat surface that faces the wheel) and the little part that swoops back down (at the bottom) immediately in front of the rear wheel (this is the area that takes the beating).
Line-X is a product similar to ABS plastic that is sprayed into pickup beds for protection. They are able to color match to body color only so so. I think that the heavy wear areas as you said would be the best spots.
