Streaks on driver's side window
There is a streak on the window at the driver's side after the opening and closing of the window. I understand that it may be caused by some dirt on the window regulator pad. I guess the dealer can take the door apart and change the regulator pad. But the problem is that I am not comfortable with them taking the door apart. I am worried that more noise and rattles will be created after having the door is being taken apart. What do you think?
I have the same streaks. Doesn't happen all the time, fairly often. I'm like you, once you take something apart you can't ever get it perfect again and rattles could pop up. So for now I just wipe the windows and deal with it.
