996 Forum 1999-2005
New Deck advice
Old May 15, 2005 | 10:22 AM
tpitpit's Avatar
tpitpit
Default New Deck advice
Hey all,
I want to replace my deck after the gremlins have killed my stock one. My deck has all functions but no volume control. It was a sporadic problem but now its permanent. (99 C2 Cab)
I went to tweeter and they said I would need to rewire to get a nonstock raidio in there. Is this true? What kind of deck should I get?
I want to ditch the useless stock amp and deck and replace it with good stuff. What do you guys recommend? I have about a grand to play with.
Tony
Old May 15, 2005 | 10:52 AM
dmgcfg's Avatar
dmgcfg
Contact Rod Birch at Car Audio Innovations. Rod is the best when it comes to 911 audio and is a site sponsor. Go to the Sponsors section for his contact info and access to his website.
Old May 15, 2005 | 01:08 PM
djantlive's Avatar
djantlive
If you are changing the HU, would you like to keep the stock look? Alpine and eclipse are nice.
Not sure on the amp but there are no doubt many choices. Get something that is compact and runs cool (MOSFET / high current).
After that, you'll want to upgrade speakers!
Old May 15, 2005 | 02:04 PM
David in LA's Avatar
David in LA
Tony - If you are going to be tossing out your deck I would be interested in some of the parts...my deck has the paint coming off on the "power" and "eject" buttons.
Old May 15, 2005 | 07:13 PM
tpitpit's Avatar
tpitpit
You are welcome to the parts if you answer the original question. Do I need to rewire the car or can I get another deck like an alpine and put it in.
Old May 16, 2005 | 05:30 AM
David in LA
You can put in an aftermarket radio and keep the stock wiring if you use a harness adapter. Using a harness adapter is the easiest way to do a mid-price install. If you are going high-end (say $4000-6000 system) you'd be better off rewiring the poser, speaker leads, amp leads, etc with more robust wiring.
The harness can be purchased at Crutchfield, etc, but I as others have advised I would contact Rod Birch at caraudioinnovations.com as all he does is Porsches....he can give you a good bang for buck recommendation for head units and amps plus he indcludes all the necessary parts/adapters for a DIY install.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
