first mods - interior
OK. They are in. It was not necessary to remove the alien eyes. The light fixture pops out when you lever it out with a small screwdriver on the front side.
Light color is novel and maybe OK. The LEDs provide much less illumination. I'll know tonite whether there is actually enough to be useful.
in the uppers i will probably keep the xenon, but i think i will put LED in the door because you can't turn them off and i think heat will be an issue.
With black interior it looks amazing imo!!! looks novel - come on it matches the headlights and you know how good those xenon's look when you see a car coming at you.
Originally Posted by Cpa4S
here is the link - it looks like they remedied the heat and burnout issue by using LED.
the 10 bulb set for an E46 cab should work. - $50
they give great shots of the before after look.
www.bimmian.info
www.bimmian.info
John
