996 Forum 1999-2005
Suspension feels floaty?
Old Apr 15, 2005 | 09:55 PM
Dale Gribble's Avatar
Dale Gribble
Pocket Sand
Default Suspension feels floaty?
It might just be in my head, but the suspension on my car is not as hard or as "sharp" as it was. Then again after driving a 97 civic with everything broken on it all winter, my sense of suspension could be off.
It might also be because my car went on a diet over the winter: Spare tire and tool kit (thats gotta be like 40 pounds), bypass pipes 55 lbs, gt3 seats 30lbs i think, if not more, and some other little ods and sods to equate to roughly 15-170lbs lost. could this be the reason the suspension doesn't feel as sharp? because the factory M030 is set up for a certain weight and needs harder springs and different damnping to compensate for the lost weight?
or should i just take the little pills that my doctor keep giving me.
other pertinant info: car just rolled passed 35000 kms. its is stored on blocks during the winter with the rims still on so that might have pulled down on the suspension and fudged with stuff (although i don't know why i didn't notice it last season).
Old Apr 15, 2005 | 10:58 PM
SPR's Avatar
SPR
stored on blocks???? Do you mean the wheels off the ground and shocks at full droop? If so that is a huge mistake and the shocks leak if fully extended for even a moderate amount of time
Old Apr 15, 2005 | 11:02 PM
bullbear's Avatar
bullbear
I was told explicitly not to store the car on blocks for exactly that same reason. I think your "floatiness" could definitely have something to do with that. I just store mine with tires overinflated to prevent flat spots and with the battery maintainer plugged in.
Old Apr 15, 2005 | 11:03 PM
Dale Gribble
Pocket Sand
werid...i was always under the impression that leaving a car on blocks or jackstands was a fairly common practice. i inspected the shocks before/after bringing it back down and there didn't seem to be any fluids leaking.
Old Apr 15, 2005 | 11:08 PM
SPR's Avatar
SPR
You wouldn't see any leaks in that manner. I would bet that was the issue. That is why most shocks come with strapps holding them compressed when new-
Old Apr 16, 2005 | 08:56 AM
Dale Gribble
Pocket Sand
sheize....time to move ahead with the upgrade i guess.
is there any danger driving the car as is for the time being (another couple of weeks till the shocks come and are installed/aligned?)
Old Apr 16, 2005 | 09:29 AM
JS's Avatar
JS
Go with the X74 if you have a 996.
Old Apr 16, 2005 | 10:39 AM
Dale Gribble
Pocket Sand
ican't get X74 on a 1999. my mind is fairly made up: PSS9's.
Old Apr 16, 2005 | 01:54 PM
SPR's Avatar
SPR
You can drive it without any problems. The telltale sign is that it is underdamped and pogos through more than 1 revolution
Old Apr 16, 2005 | 02:04 PM
Dale Gribble
Pocket Sand
pogos?
Old Apr 16, 2005 | 02:06 PM
SPR's Avatar
SPR
goes throgh more than one perfect co-sign wave static ride- compression- rebound- and ENDS at static, whereas an underdamped shock will keep going
Old Apr 16, 2005 | 02:11 PM
roberga's Avatar
roberga
Dead eye: I had PSS9s on my 2002 C2 and they were great! If you are going to track the car it is a good way to go. Adjustable height,corner balance adjustable ride. X74 no corner, no adjustment. Great for street but not for track
Old Apr 16, 2005 | 08:27 PM
Dale Gribble
Pocket Sand
^ yeah that was the conclusion i came to. my car is driven hard and i like 2 tweek settings to get them just right. PSS9's will give me that opportunity and keep the "****-up-ability" to an acceptable level as opposed to say Moton's.
