sunroof adjustment??
Hi
Open the roof about 80mm and push the trim panel back off its two clips at the front by about 30mm. Then tilt the roof and push the trim back as far as you can...It's quite fragile and there is a water drain at the back..go steady!
There are 4 torx screws holding the panel to the side runners, there is about 8mm of adjustment available..sorry for being all european and metric!
It should sit with front either flush or -1mm and rear flush or +1mm.
Hope this helps.
Hope this helps.
