Confirmed - Speedometer is incorrect - Is there a fix?
Okay info. Spoke to the local stealer, err...dealer. He said Porsche notes to the techs a 10% (WTF?) allowable discrepancy. Hmm...
He did confrim that the odometer is seperate and run off the dif. I am going to try and have the instrument cluster flashed to reprogram it. Maybe that will help. Who knows...
C.
C.
Originally Posted by SRL
True story? I'm going to be watching my odometer like a hawk now! 997 here I come!!!
I got the same 10% message from my dealer when I asked. Mine reads about 5 MPH high but its more of an offset over 35 or so than a % delta. For example 40 indicated = 35 and 65 indicated = 60. The 10% threshold is at 60 MPG so I am within tolerance.
Keep us informed if the flash fixes the issue for you Chad.
So when you hit your 50K and the warranty expires, then you could potentially still have almost 5K left to get tot a true 50K. Sounds like a warranty scam to me I wonder how much it saves them in warranty work. Do the math.
I understand from previous threads on renntech.org that most 996s are about 5%-10% over on speedometers, but spot-on accurate on odometers. I must say, I don't mind that much--it means when I think I'm doing 80 it's only 72, so PAG is helping me keep out of more serious trouble with the law...
My speedo also reads approx 5 kph (3 mph) fast at 60 mph. I had it paced against a couple of other cars (obviously not a precise measurement) and my speedo consistently reads a bit fast.
I did ask the dealer about it when in for service. They said they checked it and it was "within tolerance". As I recall, hey said that within 5 mph is within allowed tolerance.
