How do I remove entire overhead map light/sunroof switch console
My sunroof switch has come unclipped in it's place, I need to remove surrounding housing that contains map lights and snap sunroof switch back in place. How do I do this without breaking any clips?
level off the motion sensor covers and unscrew the two philips head screws. Pop out the large light out and there is another screw there or two. The rest is held in with clips but it has hooks towards the front so you would pull down from the part closest towards the rear and then push it forward to clear the tabs without breaking them.
