Air Pressure for 19 inch wheels
TimSippel (02-24-2021)
Also keep in mind that the 997 runs a "taller" wheel/tire combo, so 19s on a 997 have more cushion from the tire. My biggest worry running 19s would be rim damage, which would have me running at least the factory reco'd 36f/44r; if not higher.
i use 36F/44R
my setup
245/35-19F -> 25.7" diameter
285/30-19R -> 25.7" diameter
stock 1999 996 18" using conti sc2
225/40-18F ->25.1" diameter
265/35-18R-> 25.3" diameter
997S 19" wheels using conti sc2
235/35-19F-> 25.3" diameter
295/30-19R-> 25.9" diameter
looks like there a 1% difference in diameters between 18" stock 996 diameters and 19" stock 997S diameters. my wheel/ tire setup is within 1%, within the factory tolerance.
(all specs from tire rack)
my setup
I use 36f/40r. No rim damage in 40k miles and the last set of Goodyear Eagle F1 GS/D3's have so far lasted 9,000 miles and there's plenty of meet on them yet!
