996 Forum 1999-2005
Suspension questions
Old 03-03-2005, 04:27 PM
c4bliss
c4bliss's Avatar
Default Suspension questions
Ok, question. I have two choices i have to make. I cant do both the PSS9 and the H/R sways at the same time and am considering starting with the H/R sways first, before the PSS9 install. I would like to see how the handling would change with the sways in, before dropping the dime on the PSS9 set up. Anyone have experience with sways only? Should i do the sways first or the PSS9's? Any help?
Old 03-03-2005, 04:36 PM
Eli at Pelican
Eli at Pelican's Avatar
I'd do both at the same time so you only have to deal with a proper alignment once......
Save the money for beer or something....
Old 03-03-2005, 05:00 PM
TT Surgeon
TT Surgeon's Avatar
Youi should just do the RoW 030, more than enough for your car.
Old 03-03-2005, 05:12 PM
LVDell
LVDell's Avatar
I am doing the RoW M030 in 3 weeks. I just got it in and have scheduled the install for later this month. I took pics and measurements last night. Then I can not only compare stock vs. RoW M030 handling feel but the F/R height change as well. I got the entire kit with F/R shocks, springs, stabilizer bars for $1K shipped. Much better than the $2K plus for the PSS9 alone. I plan only only tracking the car 1/2 dozen or less times a year (time permitting).
I will post results when instsalled.
Old 03-03-2005, 05:32 PM
mightytaco
mightytaco's Avatar
$1k shipped? That sounds like a good deal! Do you mind if I ask from where?
Old 03-03-2005, 05:58 PM
LVDell
LVDell's Avatar
Just PM'ed you.
Old 03-03-2005, 06:01 PM
stiles_s
stiles_s's Avatar
Location: Bellevue, WA; '18 Macan S, '10 997S, SPASM, 6spd
C4bliss: if you want to start off gradually, go with the rear sway only from the ROW/US 030 package. It'll get rid of a large amount of your understeer and still preserve a good ride. I ran this way for a while until I cobbled together the $$ to get the rest of the kit installed.
FWIW, I love the ROWM030. Huge improvement, and looks much better too.
Old 03-03-2005, 06:04 PM
c4bliss
c4bliss's Avatar
Will the row30 stiffen or control the sway of the car on corners? It is all over the place on corners and that is really buggin me...
Old 03-03-2005, 06:25 PM
stiles_s
stiles_s's Avatar
Sway is significantly reduced, as is the "vertical" motion in the suspension, especially in front. The car is very nicely buttoned-down now.
Great compromise for the street, imo.
Old 03-03-2005, 06:30 PM
SRL
SRL's Avatar
If you can only do one, would do sways first, then PSS9's.
Don't worry about the alignment, you don't need to re-align if you're only doing a sway bar upgrade, only after you do the PSS9's.
Old 03-03-2005, 06:53 PM
leedav
leedav's Avatar
How does ROW M030 compare to US M030 in height and stiffness? Would an ROW rear bar clean up understeer on US M030? Opinions?
Old 03-03-2005, 06:57 PM
c4bliss
c4bliss's Avatar
ok, have anyone installed the techquipment row m030 10mm lowering kit? From my conversations with the dealer, it wont lower the ride but will stiffen it up and decrease the sway.
Old 03-03-2005, 07:39 PM
stiles_s
stiles_s's Avatar
That's the US 030 sport suspension option. Since the ROW (rest of world, by the way) M030 only lowers slightly more, and from what I've read is a big upgrade from US 030, I'd go with that. also, the pricing is very similar between the two.
Old 03-03-2005, 07:41 PM
stiles_s
stiles_s's Avatar
US M030 Sport Suspension
Front Stabilizer 9.58% stiffer
Rear Stabilizer 24.15% stiffer
Front Springs 16.6% stiffer
Rear Springs 28.2% stiffer
Front Shocks (rebound) 21.1% softer
Front Shocks (compression) 13.7% softer
Rear Shocks (rebound) 26.1% stiffer
Rear Shocks (compression) Same
ROW M030 Sport Suspension
Front Shocks (rebound) 8.1% stiffer
Front Shocks (compression) 9.6% softer
Rear Shocks (rebound) 36.1% stiffer
Rear Shocks (compression) 15.2% stiffer
The ROW is approx 20mm lower than US 030, IIRC
Old 03-03-2005, 08:02 PM
LVDell
LVDell's Avatar
US M030 lowers 0
RoW M030 lowers 10mm rear and 20mm front
I have a great article that talks about the differnce between US Std/Sport and RoW Std and RoW Sport. FYI....there is no difference in height between the US std and sport suspension. If you want to lower the ride hieght you need the RoW sport suspension.
Just PM me if you want the article.
Quick Reply: Suspension questions
