Suspension questions
#47
SRL,
Sorry but I have no idea. My exhaust system is two eight inch long peices of 3 inch pipe that run from the headers straight out the back. I would consider quality, sound and weight. It seems like you should start with a board sponsor and work from there.
Rob,
Adjusting height is pretty easy. You just spin (with a tool which is provided) a collar that adjusts the relationship between the spring perch and the damper. The tougher part is that you will need to realign the car. Not a big deal. The other thing to check on is what the max height acheivable with PSS9s is. The max height might not be as high as you want to go in the winter. I don't know. Just guessing.
Jim
Rob,
Jim
#48
Chandler!
Jim,
Thanks for the info. As long as the max height is about what the car is standard I'll be fine. I have my tires swapped out every winter and when i do I have them align the car if necessary. I'll just have them adjust the suspension when they swapped the winter wheels.
Rob
Rob
