Work finished. (For now) The result >>>
My fabricator modified (shortened) my links. Not sure if the modification is the same for your spring/shock upgrade as it was for my coilovers, but it's probably similar.
It is the same instance with my combo. How much shorter are the links? I know of a good fabricator. Maybe I can get them made as well.
Chad
SRL - Could you measure the O.D. (outside dimension) of the drop links for me? I will get them fabricated. Who knows, maybe I could have a bunch manufactured and sell them.
Chad
The front seems to be sitting too high with the H&R's. Seems like it will need to settle A LOT to get the proper look. Maybe it is the picture angle??? Take a few measurements from the floor to the center of the fender arch and let us know where she comes in at... might want to measure the rear while you are at it...
Chad
Also, maybe take it in the garage where you took the first one so the naysayers can see the before and after settling pics.One again, great work! Saved yourself a cool $1K in install costs that you can use for more mods!!!
Cheers,
Dell
You have the front pretty stiff and the rear pretty soft, so these settings are biased towards understeer. I have found personally, however, that although the stiffer end gets much more weight transfer, it doesn't tend to slide as much as I would expect based on past cars I've modded. After extensive playing around with alignments, I've found this to be because our cars have such low-profile wide contact patch tires that the increased load on the tire is partially offset by reduced body roll from the swaybars which keeps the tire patch in better position. It's kind of a win-win situation and why I love big swaybars.
Also, understeer and oversteer are transitional conditions. Slower corners will tend towards more understeer while higher speeds will tend towards more oversteer. A car set up for low-speed autocrossing will be handicapped for high-speed road racing. Personally, I like to have the non-driven end slide more (greater slip angles). For example, FWD cars, I like oversteer so I can power understeer it through the corner. For RWD, I prefer an understeer bias so I can power oversteer it in a corner. Right now, I'd like to get a little more understeer bias so I can put more power down in a corner as I'm limited to 3rd gear for most sweepers. One of the biggest factors I've found for tuning under/oversteer is tire pressures. For me, the factory fronts are way to low (Boxster S).
In skilled hands, oversteer can get you out of trouble while you countersteer and bleed off speed or hook the rear around while understeer will only get you to plow off the road. In unskilled hands, oversteer can get you in a spin with disastrous results while understeer is more forgiving. A lot also depends on your alignment and driving technique and I'm sure my technique is biased towards wrangling my FWD cars of the past (ricers).
