Check Engine Light Wont Go Off
Last week my engine light went on and I realized that I left my gas cap at the gas station. No luck in finding it so I bought a new cap at a local parts store ( Not Porsche). I have driven the car for 5 days now but the light stays on. What sensor is telling the computer that the cap was off ? Do I need a new Porsche gas cap? Do I need to wait longer?
If you replaced the cap with the correct cap, the light should go off in several drive cycles. If you want it off immediately, disconnect the negative cable on the battery for a few minutes and then reconnect. Depending on the year of your car, you may have to reenter the 4 digit radio code. Your car will run a little rough for a while until the computer relearns the proper settings.
You can't reset OBDII fault codes by disconnecting the battery. Although, the
tank venting & leaking are part of the OBDII diagnostics, I wouldn't assume that's
the source of your problem, although the correlation is logical. I would:
1. buy an OBDII scanner for checking the faults & resetting codes, < $100 now
2. find an independent Porsche with the PST2 tester
3. go to a "big box" auto supplier & have them read the code
4. go to the dealer
Bottomline: Don't drive with the fault code present too long as you might have
a costly repair to deal with in the future.
4. go to the dealer
Took the car to autozone, they scanned the computer, found out that it was in fact evaporation from the gas cap being off and reset the CEL. Took about 4 minutes and they didnt charge me a cent.
"If you disconnect the battery (for at least 2 minutes) it will clear the light."
As I said; "You can't reset OBDII fault codes by disconnecting the battery."
The fault memory uses flash memory technology which is non-volatile to Vcc (battery voltage).
"Took the car to autozone, they scanned the computer, found out that it was in fact evaporation from the gas cap being off and reset the CEL. Took about 4 minutes and they didnt charge me a cent."
Great, that's the way to solve the problem, the right way.
